Python & global Variable
  • March 6, 2013
  • 330 views
Hi all
I use a PythonCaller to compare the output from some transformers with a textfile. Depending on the results I would like to set a global variable or modify a published parameter.
In the further workflow I would like to use the parameter to determine if the features should be written out or not.
As a workaround I used a VaraibleSetter and VariableRetriever to set a global variable which I can use in a Tester. It yould be more elegant to set and expose the global variable or modify a published parameter within the python Caller.
  1. Is it possible to change the value of a published parameter within a PythonCaller? If I try to fo modify the published parameter with FME_MacroValues['NameOfPublishedParameter'] = "Yes", it doesn't affect the value. The default vlaue will be used.
  2. Is it possible to set and expose a glaobal variable (function or factory: @GlobalVariable) analog to the VariableSetter/VariableRetriever combo?
Thanks for any advice
felix
Best answer by david_r
Hi Felix,
unfortunately, I do not know of any way to set/get variables like the VariableSetter does.
You can, however, set a session variable in one PythonCaller that you can retrieve in another PythonCaller later on, if that is of any help. The easiest is probably to define a variable (or dictionary, etc) in the startup scrip, such as:
my_global_value = 0
global my_global_value
You can then reference and modify my_global_value from the various PythonCallers in your workspace.
If this does not solve your problem, I would consider taking a step back (figuratively :-) and see if it is possible to separate the loading and the validation of the data. This is a common way to do it when importin into a database schema with strict constraints:
  • load input data (e.g. csv, shape, etc) into a validation schema (copy of production schema, but without any hard constraints, relationships, etc)
  • try to apply constraints one by one on validation schema
  • if everything ok, transfer data to production schema, if not, report error
This is of course very simplified, but you get the idea.
Hope this helps.
David
  • March 6, 2013
Hi Felix,
unfortunately, FME_MacroValues is considered read-only by FME, so any changes you make to the dictionary values will not be propagated back to the running session. In fact, I believe that it isn't possible to change the value of the user parameters during run-time at all, regardless (I'd be glad to be proved wrong on this one!)...
Two alternative strategies:
  1. Initialize the parameter value using a Python scripted parameter, or
  2. Have the PythonCaller create a new attribute, which you then reference in your workspace rather than the user parameter.
Hope this helps.
David
  • March 6, 2013
Hi David,
Thanks for your answer. That's too bad.
The whole workbench is for data processing and quality assurance. After processing some data I do quality checks. The output is then compared with a text file, where exceptions can be defined, in the PyhtonCaller.
So, I can't use a scripted Parameter. I think I have to stick to the second strategie and use the VariableSetter & VariableRetriever combo.
Is it possible to use a transformer within the PyhtonCaller (VariableSetter) or set a GlobalVariable?
thanks
felix
  • March 6, 2013
Hi Felix,
my_global_value = 0
Hope this helps.
David
  • March 6, 2013
Hi David
Thanks, that solved most of my problems. First I tried to access the global variable within a scripted parameter. As you mentioned earlier, that doesn't work.
Now I set the global variable in the PythonCaller (btw. you flipped the order, first global parameter, then parameter ="text"). Instead of assigning the variable to each feature and unsing a Tester I use a second PythonCaller and test programatically for the global variable.
Thanks for your help
felix
P.S.
With the VariableSetter you can set a variable. Later you can asign this variable to an attribute (VariableRetriever).
In my case I createed one feature with an attribute in the PythonCaller and used the VariableSetter. All processed features went into an FeatureHolder. I asigned to each feature the attribute from the PythonCaller with the VariableRetriever. In the end I was able to test for his attribute.
