How do I make a bounding box to SDE without the original points trying to save it in the same feature class?
  • January 15, 2015
  • 22 views
I want to create a bounding box from grouped points (by permit number).  I used the BoundingBoxAccumulator and in the inspector it comes out great except that it also is writing out the points!  When I try to save this into the SDE as a polygon feature class, it fails and says that it doesn't accept multiple types of geometry...  I also want to save out the points as well =, so how do I seperate out the points and lines into 2 seperate feature classes (appending existing).
Origionally, In ArcToolbox, the tool I used was "Minimum Bounding Geometry", if that helps....
fmelizard
Forum|alt.badge.img+21
  • January 16, 2015
Separate the geometries via the GeometryFilter and write to separate feature classes.
gio
Forum|alt.badge.img+15
  • January 16, 2015
it only outputs the originals through the "Original" output and not the BB output.
  • January 16, 2015
Gio- It does not save out like that, I tried several combinations and it failed everytime.  GeometryFilter was the fix!
