Add xdata to an existing DWG file
  • December 6, 2012
  • 6 replies
  • 84 views
I have
- 16 dwg that are our original workfiles without xdata
- a DXF file which is the result of a FME treatment and which contains xdata
I created ID for several layers and I need to retreive this IDs so when we will update our workfiles, and I will pass them into my treatment to make a new DXF file, my IDs for existing features won't change.
I have to retreive the xdata "ACCESS1_ID" from the DXF to put it, as XDATA in my orginal files (DWG).
I have a way to merge correctly the DXF with the original files thanks to a block attribute I have kept as a xdata in the DXF.
But I don't manage to obtain a file which would be exactly the same as my workfiles (DWG) with adding xdata in it.
Thank you for your help.
Charlotte
sigtill
Forum|alt.badge.img+25
  • December 6, 2012
Is the difference between your old and new file that some attributes are missing, or are there missing geometry on the new files?
  • December 6, 2012
I tried different ways....
- without template file : there's no geometry at all in the result
-defining my dwg (i'm trying to do it only on 1 dwg fisrt...) as template : the result is : i retreive my entire features in the result but instead of adding a xdata, it duplicate my blocks and there is no xdata...nowhere.....
I tried the option : fanout by attribute with fme_feature_type, so the feature will go back in the right layer in exit.
  • December 7, 2012
The french support found my error :
The parameter : add data to the template (not sure it is the exact name in english... "Ajouter les données au modèle" in french), was set to : YES
All I had to do was to set it to : NO
Now i hope i will be able to do the same with the other feature type of my file and to do it with the 16 dwg files i have in the same time!
sigtill
  • December 7, 2012
Thanks for also providing the answer, as this will be usefull for other people experiencing the same problem
  • December 7, 2012
I managed to retreive the data in every feature type but now I'ma having trouble to retreive it for several files at the same time.
I set 2 files in the input instead of one, and ask to fanout by fme_basename on the output.
The result is :
-on the first file, I retreive all the xdata I asked for
- on the second file, I don't retreive any xdata on the fme_line and I retreive xdata for maybe 20% of my blocks. (It should be 100%).
Something on the output must happend because when I'm visualising after the last transformer my data in the fme viewer, I can see the attribute I want to add as xdata.
Any leads?
  • January 7, 2013
I found out the problem just before Christmas.
I change the parameter : "output defined attributes only" to NO,
Lucky move, it worked!
