Access a Secured FTP Site and Download the Dataset
  • September 6, 2013
  • 23 views
samisnunu
Forum|alt.badge.img+10
In a workspace, I will regularly update a source that is available as a zipped shape file from a secured ftp site with a username and password.
So I’m using the shape reader, and using a path like(ftp://<3.ftp/*_*.zip) in the FME shape file reader location, but FME returned the following error when running the workspace
ERROR |Shape Reader: No Shape Files found to process in directory,…
Obviously, I need to pass my logging credentials to download and read the zip file, so how can I pass the username and password in this case?
Sami
Best answer by takashi
Hi Sami,
Try this syntax:
ftp://<user>:<password>@<ftp server name>/<directory path>/<file name>
Takashi
  • September 6, 2013
Hi Sami,
Try this syntax:
Takashi
samisnunu
  • September 6, 2013
Thanks Takashi,
This works as you answered!
