attributes based styling
  • April 20, 2015
  • 12 views
Hi I am trying to convert shapefiles to DXF.
I have a CAD template file (.DWT) which contain definitions for linetypes.
However I need to specify a linetype based on an attribute.
I am using the DWGStyler in FME. Is there any way to set a particular linetype based on the feature subtype.
Best answer by pratap
autocad_linetype attribute has to enabled on writer as well as it should be defined with line style based on feature subtype.
Pratap
pratap
Forum|alt.badge.img+12
  • April 21, 2015
Pratap
