Write in the same FGDB as the source?
  • February 2, 2018
  • 12 views
I would like to add a new attribute filled in by the workspace in an feature class that is in a feature-dataset in an existing FGDB.
Can you help me ?
Thank you
PS: I am still in v2012 SP4
  • February 2, 2018
I forget, this is in dynamic schema !
danilo_fme
Forum|alt.badge.img+53
  • February 2, 2018
Hi @40_eme,
Did you try to Import the Dataset?
Readers -> Import Feature Types
Thanks,
Danilo
  • February 6, 2018
Hello,
I don't have this option in the writer in v2012 SP4
Thanks
