- DWG-Reader
- TAB-Reader
- ECW(Orthophoto)-Reader optional
- PointcloudXYZ(DEM)-Reader optional
The ECW and DEM files are not needed every time. At the Parameter (Type: Filename(Multiple)) Published and Optional are activated.
The Process only run when i select some ECW and DEM files.
When i don´t select i get this error message in the log:
INFORM|POINTCLOUDXYZ reader: Directive '_FIELD_NAMES' has the value 'NO' |INFORM|POINTCLOUDXYZ reader: Directive '_FIELD_NAMES_AFTER_HEADER' has the value 'NO' |ERROR |POINTCLOUDXYZ reader: Failed to open file '.' for reading. Please ensure that the file exists and you have sufficient privileges to read it |ERROR |BADNEWS: A fatal error has occurred. Check the logfile above for details (dynaread.cpp:265) If I disable the ECW/DEM-Reader in the Navigator the process runs without an error. However, then my Colleagues have to intervene manually. This, however, I want to avoid.
how can I solve this problem?
