Strings with numbers
  • January 27, 2016
  • 5 replies
  • 103 views
pushpa
Forum|alt.badge.img+9
I have a Shapefile with 9000 records and one of the attribute columns contain strings (numbers and letters). Column width is set to 4 characters
I need to find all records with last character is a "letter" and delete that letter.
ie:
ST4W
S4W
Above records I would like to delete "W" from the records
Could someone help me to do this using FME?
thanks
Best answer by erik_jan
You can use the StringReplacer, use the regular expression [a-zA-Z]$ to remove the last character if it is in the mentioned range and replace with nothing. Or use [a-z]$ and case sensitive No.
erik_jan
Forum|alt.badge.img+26
  • January 27, 2016
davideagle
Forum|alt.badge.img+22
  • January 27, 2016
SubStringExtractor to extract the 4th character to new attribute.
AttributeClassifier to test that attribute to see if its Alphabetic.
Records that pass go through another SubStringExtractor and extract values 0 to 2 or 0 to -2 from the original attribute to a new attribute or overwrite the old one.
Or do some Regex magic...no doubt about to appear below this post...
davideagle
  • January 27, 2016
or above this post... I was too slow!
pushpa
  • January 27, 2016
Thanks. not sure what I am doing wrong,
I didn't get the results I expected.
davideagle
  • January 27, 2016
Here you go if you want to try it with a couple of standard Transformers.
stripofflastchar.fmw
