Comparing SDE Data between versions
  • January 9, 2013
  • 24 views
I have a requirement of comparing ARCSDE data between the versions and extract the changes either spatial or binary data from that are made in the versions. I am trying to add the SDE data into FME reader, but it shows error message. Can any one please help me that are required parameters and necessary support ESRI applications to add the SDE data into readers.
  And also can anyone share the workbench or approach that how to extract the differences in the SDDE versions.
Thanks in Advance.
Seshu.
davideagle
Forum|alt.badge.img+22
  • January 9, 2013
The first thing to get past is the error message, which may be to do with your FME Edition, your ability to access the third party ESRI license (often the first problem) or perhaps something else. Perhaps you could post the error part of the log to allow someone to offer advice.
sam
Participant
  • Participant
  • January 13, 2013
If you are using ArcGIS 9.3 and above you can compare versions using inbuilt ArcGIS "version changes" tool.
