Dynamic writer user attributes
  • January 25, 2013
  • 31 views
owen
I have a workspace that writes out an excel file using a dynamic writer, to which I have added some user attributes.
The output puts the user attributes at the end of the dynamic schema attributes, ie, in the last columns of each excel worksheet.
Is there a way to control the order of these field using a dynamic writer?
davideagle
Forum|alt.badge.img+22
  • January 25, 2013
I haven't used it myself, so you'll need to experiment but I think the 'Schema (From Table)' Reader may give you what you need here. Especially if you ensure you use the 'Attribute Order' parameter.
Failing that a Workspace Resource may help.
Some info here:
http://fmepedia.safe.com/articles/Samples_and_Demos/Dynamic-Schema-Examples-FME2011
owen
  • January 25, 2013
Thanks Dave, I'll give it a bash
