Adresses on Area - Lists - AttributeCreator
  • February 5, 2020
  • 5 replies
  • 35 views
featuremichael
Forum|alt.badge.img+9
Hello FME Community,
i need help to understand how i can solve my problem.
The outcome should be a Excel-File where all Adresses on a parcell should be stored.
1.)i got Points(Adresses) and Areas
2.) Use the PointonAreasOverlayer and make a List on the Areas.
3.) Use the ListExploder: Take the List and Create a _element_index (rest is standard)
now comes the part that i dont really understand.
4.) i use the AttributeCreator for Creating Attributes like "@Value(_element_Index)Adress" = "@value(Adress)"
then i use the "centerpointreplacer" and a "pointonpointoverlayer" to merge the "new" attributes
then comes the duplicatefilter(group = ID) to get the unique Adresspoint with all the AdressesStored in a parcell.
and then comes the tricky part: after i use the AttributeCreator my Created Attributes where gone but when i redirected it to the datainspector my attributes where stored an the "Areas"
and that was it. I tried to write, after the attributecreator, a ffs-files and use this file for the workflow but it does not work :(
i hope someone can help me.
Thank you, Michael.
Best answer by featuremichael
Thank you guys for your help,
i found the solution,
i had to define my created attributes in the Excel-Writer and it worked flawless.
i tought with the "Automatic setting - for Attribute Definition, it will create this Attributes - but it will not work that way.
nielsgerrits
Forum|alt.badge.img+64
If I understand correctly you want to add attributes from parcels to address features. Then why use the Area output port and not the point output port?
featuremichael
  • February 5, 2020
no, i want to add, 3 Attributes[Street,Nr,statecode] from my Adress points, that can be 1 or more on one parcell
and the excel-file should look
CountryCode,PalcellNr, and then 1Street,1Nr,1Statecode,2Street,2Nr,2StateCode
  • February 5, 2020
@featuremichael ListBreaker which is a custom transformer might be what you need.
erik_jan
Forum|alt.badge.img+26
  • February 5, 2020
To rename the attributes to the 1Street etc. you could use the BulkAttributeRenamer (prefix with _element_index attribute).
featuremichael
  • February 6, 2020
