Fme workbench is still running
Why does Fme workbench is still running after Translation was successful message is displayed in the translation log window ?
Best answer by david_r
in that case, I strongly recommend that you upgrade to at least SP4, which was the latest version of FME2012.
It is available by ftp here: ftp://ftp.safe.com/fme/2012/
David
