Search Envelope of a reader : values as parameters from another reader
  • June 14, 2013
  • 86 views
Hi !
I have a reader on my FME Desktop 2013 workbench which opens data from an Oracle spatial database.
Reading the data take a long time, since it is a huge dataset.
The first step of my process is to use a SpatialFilter in order to select the features of my dataset which are included in a relative narrow region.
This means that I opend a lot of data that are not used in my process.
In order to avoid this, I can specify a Search Envelope in the parameters of the Reader. I guess that by doing this I only open the feartures that are within this envelope.
My question :
In the Search Envelope, I have to manually define the Min X, Min Y, Max X, Max Y values. Is it possible to derive these values automatically from another dataset ?
My idea is to add another reader on my workbench to open the delimitations of all the municipalities, to "TestFilter" this data in order to select only the municipality I need, to derive the Min X, Min Y, Max X, Max Y values of this municipality, and finally to use these values as a input parameters of the Search Envelope of the reader from which I need the data.
Thanks !
  • June 14, 2013
you can publish the Search Envelope parameters by right-clicking them. You can then create a second workspace that reads your bounding feature and passes the search envelope to the first workspace using a WorkspaceRunner.
Alternatively, look into replacing the Oracle reader with a Feature reader.
David
fmelizard
Forum|alt.badge.img+21
  • June 14, 2013
It this case a Feature Reader is the best option.
You can read the municipalities feature(s), pass via a tester to select your feature of choice (for example municipality name). Edit/create a published parameter, import the municipality names from the feature(s).
Now you can use the parameter in the tester, to select you feature of choice when prompting.
Connect that to a Feature Reader and configure it intersect (or a spatial test of your choice).
Hope this helps
Itay
