I need a little help finding the correct format to enter a spatial envelope Input Geometry. Looking at the following link It looks like I need to put the following information into the Input Geometry Parameter (xmin, ymin, xmax, ymax). I tried this with no records being returned. Is there a trick to pre-filter spatial data from an ArcGIS Server service.
Setting the Input Geometry Parameter for ESRI MapServer Reader
