Hi
I am using the schema scanner to extract the schema of data in both the original and revised datasets by comparing with a change detector.  This is working fine and i can get everything into a single table from the insert output, however i want to be able to show delete and updated as separate tables within the email.
Any ideas of the best way to do this?
That might interest you !
