Arc as anchor in AnchoredSnapper
  • May 27, 2025
  • 6 replies
  • 136 views
mkh.rcjy
when I am using AnchoredSnapper
Reader Cad civil
Writer : oracle spatial
Anchor : arcs
Candidate : points
Snapping Type : vertex Snapping
it working fine
Anchor : arcs
Candidate : points
Snapping Type : Segment Snapping
Tolerance zero
error ORA-13347: the coordinates defining an arc are not distinct
same Snapping Distance in both
Why does this error occur when using Segment Snapping, The anchor is not supposed to move even with the Segment Snapping selected
j.botterill
Forum|alt.badge.img+55
  • May 27, 2025
The documentation explains segment snapping: snapping vertices of candidate points to their anchor, if their distances are within the specified snapping distance
“Snapping Distance” should to be set to be half the distance of the shortest line. Prior to AnchorSnapper, place a LengthCalculator and sort output length attribute to find the smallest length
mkh.rcjy
  • May 27, 2025
Thank you
I have no problem with that snapping vertices of candidate not points to their anchor, if their distances are not within the specified snapping distance
my problem is , why when using "Segment Snapping" with some arcs lead to change this arc , and raise an error when trying to insert that arc in databae
The anchor should not move in any way
j.botterill
  • May 27, 2025
yeah you may need to sample a single problem feature. Inspect it in the feature information window and in the visual preview map window. You may need a transformer like https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Transformers/Transformers/arcstroker.htm to converts any arcs to a series of interpolated line segments.
mkh.rcjy
  • May 27, 2025
thank you
but arcs is so important for me and ArcStroker change the curve of arcs
arcs are fine until they are used as an anchor from the AnchoredSnapper
j.botterill
  • May 27, 2025
unfortunately in FME terms arcs are not a Line geometry, which the segment snapping would use the line vertex…. so arc by bulge or 3dpoint can’t work with an anchor. The ArcStoker can be used to get the snapping working and you can also coercer or merge back the original arc feature
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-ReadersWriters/!FME_Geometry/FME_Geometry_Model.htm
mkh.rcjy
  • June 3, 2025
Thanks for your reply
but I don't know if it's because of the same explanation or not. Sometimes the SpatialRelator works well and sometimes it doesn't.
when :
Supplier is fme_type : fme_arc
and Requestor is fme_type : fme_point
functions :
Requestor OGC-Intersects Supplier
Requestor OGC-Touches Supplier
Requestor OGC-Contains Supplier
Requestor is OGC-Within Supplier
Tester : incorrectly classifies some points outside the intersection range even though there is an intersection, and sometimes it classifies the correct intersection correctly.
On what standard can the ARC be used, or should it be avoided at all?
If ArcEstimator  is used after ArcStroker , ARCs will it be returned to its original position completely as if I had not used ArcStroker, and thus the ARC will be insert into the database without any distortion in the curve? Is there a document for this? Thank you.
and another question please
How can I keep the midpoint of the ARC ? After Reader reading the curves, the midpoint on which the ARC was built disappears (ArcBy3Points) - source Civil CAD File -
so the curve was reconstructed using the ArcEstimator , is it built on any basis?
