Workspacerunner without writing
  • June 24, 2020
  • 30 views
alc33
Forum|alt.badge.img+14
Hi!
I have 2 workspaces. The first output shp files. The second workspace call the first.
I would like to run the first on the second, but not export shp.
I have this problem because my first workspace is used for differents uses, so in some cases I have a second workspace and in others cases I have not.
I look on the parameters of workspacerunner and featurewriter but I don't find the solution.
Thanks
Best answer by ebygomm
One way would be to create a parameter on the workspace that outputs shape files with two choices, yes and no, introduce a tester which tests for the value of this parameter and only output features that pass the test to a shapefile writer
You will then be able to set this parameter in a workspace runner to control whether the child workspace outputs shape files or not
Forum|alt.badge.img+46
  • June 24, 2020
alc33
  • June 25, 2020
Perfect!
Just a little question associated. There is a way to show the parameters of the workspace runner directly on the form when the workbench run ? I have a lot of published parameters and it will be more easy to not have to rewrite all of them on the second workbench (where is the workspace runner).
Thanks!
