PointOnAreaOverlayer not producing expected results
  • March 28, 2025
  • 57 views
scarter
Forum|alt.badge.img+10
Hello Forum,
I am experiencing an unexpected problem with what should be a simple point in polygon search process in FME Form.
I have a Creator connecting to…
FeatureReader -  reading in a point dataset of 16255 records
FeatureReader - reading in a polygon dataset, which covers a smaller area of what the points do
The two FeatureReaders feed into a PointOnAreaOverlayer.
But when I run the workspace 16255 point records are found. The number should be far smaller.
Thanks.
Best answer by DanAtSafe
Hi ​@scarter All points will pass through the PointOnAreaOverlayer.  Maybe you want to use a SpatialFilter?  Both transformers are similar.  With the PointOnAreaOverlayer, check the value of “_overlaps” and then filter on that with a Tester.
DanAtSafe
Forum|alt.badge.img+22
  • March 28, 2025
scarter
  • March 28, 2025
Thanks for that, ​@DanAtSafe . Yes, the SpatialFilter done the job. It’s clearly more straight forward for point in polygon queries.
Noted on the need for _overlaps tester when using the PointOnAreaOverlayer.
Thanks again.
