Calculating population from point located in a buffer/surface
  • February 18, 2025
  • 47 views
fme_junior
I have a first shapefile with points indicating the number of inhabitants. I have a second shapefile with surfaces. I would like to know the number of inhabitants for each surface in FME. What is the process?
Best answer by nielsgerrits
You are probably looking for the SpatialRelator. As an alternative the PointOnAreaOverlayer can be used.
nielsgerrits
Forum|alt.badge.img+64
  • February 19, 2025
