Move file from onr folder to another
  • October 23, 2024
  • 69 views
poonam21
Forum|alt.badge.img+8
Hey Folks.
I’m trying to move files from one folder to another after execution but it’s not working properly.
I have tried using filecopy writer by selecting move option, but copy is working properly but its not move.
I have also created attributes - filecopy_source_dataset, filecopy_dest_dataset, filecopy_dest_filename. But I’m not getting what value should i give into these attributes.
Kindly help.
Thanks in advance
Best answer by nielsgerrits
For moving a file, you only need filecopy_source_dataset. This is the original filepath to the file you want to move, for example:
C:\TMP\New folder (158)\from\file.txt
Then you put that in the FeatureWriter type File Copy. Dataset must be target folder, for example:
C:\TMP\New folder (158)\to
Subfolder name must have a value but can be ignored. Use the following parameters:
This setup will move the file “file.txt” from the path “C:\TMP\New folder (158)\from” to the path “C:\TMP\New folder (158)\to”.
Sample attached.
nielsgerrits
Forum|alt.badge.img+64
  • October 23, 2024
Sample attached.
