Can you provide guidance on how to convert a DWG file to a PNG image and then embed that PNG into an HTML PDF using FME? Specifically, I'm interested in preserving the visual elements like colors, hatch styles, and line widths from the original DWG file.
Here are my transformers.
Thank you.
