Help with getting my timestamp data merged correctly so ArcPro time slider will play nice with it
  • August 29, 2024
  • 75 views
schulte.a
Forum|alt.badge.img+3
Hello, any help would be greatly appreciated with this idea I have:
I am trying to figure out the least convoluted way to take my current data and get it into the format ArcPro likes it to be in to take full advantage of the Time Slider.
My ultimate goal is to use the time slider in arcpro and the user can slide the time to show how a floor was occupied throughout time.
So, I have a large amount of motion detectors. The data is fed to me like so:
SensorName Timestamp SensorStatus
1 12:00 1/1/2024 On
2 12:05 1/1/2024 On
1 12:06 1/1/2024 Off
2 12:10 1/1/2024 Off
Then Sensor 1 could be triggered again and so forth
Arc seems to want the start and end times in the same row. like so:
SensorName Start End
1 12:00 1/1/2024 12:06 1/1/2024
2 12:05 1/1/2024 12:10 1/1/2024
It needs to organize 100s of results from numerous sensors and get the start/stop times on the same row, for the correct sensor, for the correct period of time.
Best answer by bwn
OK, with sample data, something like this, using AttributeCreator Adjacent Feature Processing.
AttributeCreator Parameters
Start =
End =
Input
Output
bwn
Forum|alt.badge.img+26
  • August 29, 2024
This can be done with a Sorter (Sort By SensorName, Timestamp) and an AttributeCreator with Adjacent Feature Processing switched On (To look at next +1 Feature) with Conditional Value that where SensorName[+1] = SensorName then End = Timestamp[+1].  Finally remove the second superfluous row per Sensor with DuplicateFilter
or alternatively, Sorter  as above  , + DuplicateFiter by SensorName (To split into start start and stop time) + 2x AttributeRenamer on the two DuplicateFilter ports to rename the first port Timestamp to Start and the the second port to End and join these back together with FeaureJoiner (join by SensorName)
bwn
  • August 29, 2024
Start =
End =
Input
Output
schulte.a
  • August 30, 2024
I think that worked, thank you so much! I will learn more about the adjacent feature attribute option, I had no idea about it!
I really appreciate your time/effort/help!
