Merging Attributes with Line on Area Transformer
  • April 23, 2024
  • 71 views
ingalla
Forum|alt.badge.img+10
Hello All
I am currently modifying a workbench to chop pavement polygons based on the street id and then dissolve them back together, again based on the street id.
I have used a neighbour finder to get the nearest street and merged those attribute together with the chopped pavement line.  This all looks good as can be seen below, where each road (from a feature color setter) for visualisation is correct.
Output from Neighbour Finder
However, when i try and put these lines through the line on area overlayer to chop the pavement polygons up, different street id’s are being added to each polygon, hence i can not then disolve them back again.
Output from Line on Area Overlayer
PArt of the workbench below - not tidied up yet ..sorry
Workbench
Parameter setting for line on area overlayer below
Line on Area Overlayer Parameters
Any help on what is wrong would be appreciated.
Thanks in advance.
jkr_wrk
Forum|alt.badge.img+36
  • April 23, 2024
Maybe in stead of Merge Attributes do a Prefix attributes or Generate Lists. This way you can see what feature attributes are used in your result.
To be honest without knowing what attributes are kept in the AttributeKeepers, stating what attributes are in the output with the Merge Attributes _ Merge Incoming would be a wild guess.
Also I see lines, but can't see the area's on this zoomlevel. What size are the area’s?
