Rename Files by adding prefix from table attribute
  • April 12, 2024
  • 70 views
vxn43
Forum|alt.badge.img+18
I have 4 files I need to rename. To rename them I need to add the values of an attribute in a table to each of their names; please refer to the screenshot for this example:
would be renamed 18085SS000001.PNG by adding the value from the STCLID Attribute in the table in the screenshot to the filename.
Seems as a first step would be “move” the values in the STCLID attribute to the <missing> rows?
What is the best way to go about this?
Best answer by liamfez
If you need the STCLID values on the other features (features 5-8 in your example) to work with it there, you could utilize the FeatureMerger or a FeatureJoiner (using “path_filename” and “PHOTO” attributes to do the merge/join). You can use the StringConcatenator to concatenate the “PHOTO” (or “path_filename”) and “STCLID” attributes.
liamfez
Forum|alt.badge.img+44
  • April 12, 2024
