Python version issue
  • January 18, 2022
  • 99 views
Hi all,
I have an issue when I'm running my workspace. It throws a Python error relating to what I'm guessing is something with the python version:
File "C:\\Program Files\\ArcGIS\\Pro\\bin\\Python\\envs\\arcgispro-py3\\lib\\site.py", line 177
file=sys.stderr)
SyntaxError: invalid syntax
Warning: not all FMESessions that were created were destroyed before shutdown. This may cause instability
Warning: not all Stashed Objects that were registered were dropped before shutdown. This may cause instability
I'm using Data Interoperability extension to ArcGIS version 2020.2 and have ArcGIS Pro 2.7.2, since I need to be able to write to an SDE and we dont have that license to our regular FME version.
But I do have a regular installation of FME, so I'm wondering if the issue could be related to different python versions between the two?
I do not have any individual python software installed - everything is installed via either FME or ArcGIS.
Another colleague has experienced the exact same error on a completely differnt workspace.
have anyone come across this issue before?
I have added the fmw file for reference :-)
Best answer by nielsgerrits
Not sure if this is related, but according to https://community.safe.com/s/article/notes-on-fme-and-esri-versions-and-compatibility you need 2020.2.0.2 for ArcGIS Pro 2.7.x, you workspace is saved in 2020.2.0.0. No experience with the Data Interoperability extension, afraid I can't help more.
nielsgerrits
Forum|alt.badge.img+64
  • January 18, 2022
  • January 19, 2022
Hi Niels,
Thanks for your input - I actually hadn't noticed the slight variation in versions.. I updated to ArcGIS Pro 2.9 and since I can now choose the Esri compatibility in Translation, everything works now :-)
Thanks!
nielsgerrits
Hi Niels,
Thanks!
Nice! Happy I could help :)
