I use WorkspaceRunner in master workspace to run some specific tiling operation by slave workspace.
Nothing special. Slave workspaces are done about several seconds each. Workbench run only one fme.exe process no matter what is set in WorkspaceRunner transformer. Any idea what can be the reason?
