Re-use python script in multiple workspaces
  • November 21, 2016
  • 16 views
I am trying to re-use a python script (saved as .py file), so that i do not have to edit all my workspaces that contain this script in a private parameter.
I tried to follow the steps in
 https://knowledge.safe.com/articles/976/how-can-i-modularize-my-python-code.html
whereby I included a couple of codes within the python startup script something like below:
when I try referring the SetReader module in a private parameter, I get an error that says 'ImportError: No module named SetReader'
Can I please get some help regarding re-using python scripts ?
Thanks very much
import sys sys.path.append(r'\\fmeserver\Functions')
import SetReader
Best answer by david_r
Have a look here: http://stackoverflow.com/questions/4383571/importing-files-from-different-folder-in-python
The most important thing is that the entry you add to the Python path needs to be absolute.
You might also want to familiarize yourself with the __init__.py convention: http://stackoverflow.com/questions/448271/what-is-init-py-for
  • November 21, 2016
  • November 21, 2016
Thanks. The 1st link was of good help !
