How to identify Line Orientation? Clockwise/Anticlockwise
  • June 28, 2021
  • 159 views
anamanvil
Hi All,
I am trying to identify the orientation of a line (clockwise/anticlockwise or left/right) so that I can use Orientator transformer if a line has been drawn anti-clockwise.
In older post this seems to be achieved by using Azimuth Calculator on FME Hub; however, this does not seem to be currently available.
Is there any transformer I can use or workaround to achieve this?
Thanks,
Ana
Best answer by david_r
The AzimuthCalculator was renamed, it's now called the HorizontalAngleCalculator.
Btw, there's also the OrientationExtractor, if that's what you need.
  • June 28, 2021
anamanvil
  • June 28, 2021
Thanks for the quick reply @david_r​
