Rejected Port Error - change in error text stored in_reader_error in FME 2021 compared to previous versions
  • August 19, 2022
  • 62 views
Forum|alt.badge.img+46
There appears to be a change in message recorded in _reader_error that gets added to data coming out of the rejected port of either the SQLExecutor or SQLCreator when connecting to an Oracle DB.
Previously (in 2019.2) a failed connection to the database resulted in a single error in the translation log and the following sort of text in the _reader_error attribute
Error connecting to Oracle database: message was `ORA-12514: TNS:listener does not currently know of service requested in connect descriptor'....
or
Error connecting to Oracle database: message was `ORA-01017: invalid username/password; logon denied'.
or
An error occurred while accessing a table result for feature type `'; message was `Execution of statement
In 2021.2, I now get two errors in the log. One which contains the useful information above and a second that seems to always read
Error connecting to Oracle database: message was `%5'. (serverType=`%0', serverName=`%1', userName=`%2', password=`***', dbname=`%4')
It's this second message that then appears in the _reader_error attribute which is not all that helpful!
Is this a known issue? Is there anyway to capture the useful information about the error in the workspace, without post processing the log file?
rahulsharma
Forum|alt.badge.img+10
  • August 24, 2022
I was able to reproduce the behavior with the latest FME Desktop 2022.1.1 and have file an internal ticket FMEENGINE-74590
  • October 11, 2022
Does anyone have any clever ideas for returning the information needed within the workspace? So far I'm looking at creating a second workspace to find the error detail in the log file
  • October 26, 2022
Answering my own question, the LogMessageStreamer can be used to get all the ERROR messages from the log, and I can discard the one that contains no useful information.
