Data Inspector via Windows Remote Desktop
  • August 17, 2017
  • 8 replies
  • 54 views
Anyone using FME via a Windows Remote Desktop? Whenever using Data Inspector on my office based PC and I select a polygon feature inside the Remote Desktop session, my local machine Remote Desktop process starts to consume around 16% CPU and makes it unresponsive. Clearing the selection returns the CPU to 0%, as does minimising the Data Inspector.
This only happens when you select a feature, and the geometry is more than a simple geometric shape (rectangle, triangle, circle etc.), but doesn't have to be super complicated. Thought it was transparency related at first but it doesn't appear to be as get the same effect with solid colours.
Clearly could be an issue with the graphics driver on either PC but wondering if anyone else sees the same?
Sample data attached.
Remote Desktop running locally on Windows 10 (but saw same issue with Windows 7)
Data Inspector running remotely on Windows 7
FME 2017 (but see the same on earlier versions)
Forum|alt.badge.img+46
  • August 17, 2017
I use FME via windows remote desktop every Monday and Friday and have never noticed any issues.
Forum|alt.badge.img+62
No experience with it myself, but some anecdotical evidence from clients using Direct Access to connect and reporting similar issues. In their case it seemed to be mostly Workbench (displaying the Quick Add transformers list). How is that behaving when you use it remotely?
  • August 17, 2017
I use FME on Remote Desktop connections all the time but I've never had it go unresponsive on me the way you describe it.
However, I can confirm that something weird is going on when selecting the sample feature in the Data Inspector, my CPU usage jumps from about 0-1% to 30-ish% and stays there as long as the feature is selected. When I deselect the feature, the CPU usage goes back to 0-1% again, it's reproducible.
This happens both on my local pc (FME 2017.1) and on the remote desktop instance (FME 2016.1.2) that I tested.
After having looked into it, I think I've isolated the issue, which in fact looks like it's linked to whether the collapsed list of vertices is visible in the feature information window:
If you either add some attributes or make the Inspector window smaller so that the collapsed vertices aren't visible on screen, the CPU usage drops down to about zero. If I click on "Show All" the CPU usage also drops again. This was 100% reproducible on my PC.
Something funky is going on in the source code of that widget, Safe should definitely take a closer look.
  • August 17, 2017
No problems with Workbench remotely whatsoever.
  • August 17, 2017
Good detective work! I just assumed was because I was remote it was that, but as you say get the same issue locally.
Collapsing the entire coordinate node also works to reduce the CPU back to normal levels.
  • August 17, 2017
Yes, it seems that it's the "on-screen presence" of that particular widget that's the issue.
  • August 17, 2017
Normally OK for me as well, but have seen this before and today it really bugged me enough to ask!
As @david_r found not just related to remote desktop, but local processes. I guess when affects the Remote Desktop process maybe it is more obvious.
  • August 17, 2017
Logged with Safe Support - will post back any updates
