We are having problems with certain IFC Parameter data not being available. The IFC Exporter has been installed and all settings correct, but some shared parameters in Revit are not coming through into the FME Data Inspector. Is anyone having the same problem?
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
