Naming zipped GDB with fanout on input filename
  • May 24, 2019
  • 36 views
eric_armitage
Forum|alt.badge.img+10
I'm converting some DGN files to GDB and want to name the output files with the input filename. I have extracted the input file to an attibute called "_rootname" and done a fan out in the writer on the attribute name as shown here
This works fine. But I want to zip the output file at the same time. What settings should I use? I've tried various things but can't get it to work.
Best answer by markatsafe
Adding .zip to the end of your fanout expression @Value(_rootname).gdb.zip should give you the zipped File Geodb - see the user documentation
For completeness, example workspace (2019): zipafilegeodb.fmw
  • May 24, 2019
eric_armitage
  • May 27, 2019
Hi Mark. Unfortunately that didn't work but this did. Now I just need to set up the workspace runner so it does the same for each DGN in a folder ....
