Keep only one attribute (published parameter) renamed in a shape?
  • July 4, 2019
  • 27 views
I would like my script to keep only one attribute designated by the user in a shape in which it will be renamed. I created the workspace below.
the attribute "ATTRIBUTE" persists in keeping the value 0 while the selected attribute contains 5, 12, 8, 45 ....
Where can my mistake be?
Thank you
jdh
Forum|alt.badge.img+40
  • July 4, 2019
You are setting the new Attribute to the name of the attribute being kept, and since the shapefile writer is expecting a numeric value, it defaults to 0.
You need to either use @Value($(KEEP_ATTRS)) or use an AttributeDereferencer transformer instead.
jdh
  • July 4, 2019
Note that neither will work as expected if you select more than one attribute to keep
alc33
Forum|alt.badge.img+14
  • July 4, 2019
Hi!
If I well understand your question, you can connect reader to writer directly and create your attribute on "user attributes". Manual mode. You delete the others fields and create a new one called "ATTRIBUTE" with value = $(KEEP_ATTRS)
If you put "5, 12, 8, 45 " on the published parameter, you need to have a type = character.
