Salesforce Web Connector - TLS Compliance
Hello Guys,
Salesforce is currently upgrading their security and now they will use TLS 1.1 instead of 1.0.
With that in mind, the FME 2017 built-in Web Connector started failing while attempting to authenticate through oAuth
Network Error:Requested operation is invalid for this protocol Details:Error Text: Error downloading https://na35.salesforce.com/secur/weakhttps.jsp?l=1 - server replied: TLS 1.1 or higher required<br>Reply Url:https://na35.salesforce.com/secur/weakhttps.jsp?l=1
Is there any workaround within FME or is it related to my browser specifically? This is paramount for me as I rely on this connector for all my work.
Thank you in advance,
John
Best answer by jlutherthomas
Hi @jmoura
This should be available in the latest FME 2017.1 beta.
https://www.safe.com/support/support-resources/fme-downloads/
itay
Forum|alt.badge.img+16
  • May 10, 2017
I think that you better open a support case for this one.....
  • May 10, 2017
Thanks for the input! Already did that :)
Hi @jmoura
steveatsafe
Forum|alt.badge.img+12
@jmoura I verified this is fixed in FME 2017.1 Beta a few days ago. Good luck!
