How to create a list from pdf file names in a folder?
I have a folder of pdf files. I would like to extract the names of the files and put them into a separate rows into a column. Attached is a screen shot that shows examples of the files.
Best answer by ebygomm
You can use the directory and file pathnames reader to read each pdf in the specified folder, each file will be returned as a feature/row
Forum|alt.badge.img+35
  • July 23, 2020
Thank you for the quick reply. I think this will do the trick.
