Using multi-line labels with MapnikRasterizer
I am trying to create a multi-line label as a part of mapnik rendering. I use a string concatenator to for a a label (e.g. "top label" + newline + "bottom label" and then I render it along a line/segment. What happens is that label is rendered on the top of line/segment as ONE long label. Somehow, Mapnik doesn't honor my multi-line label representation. I tried it with FME Desktop 2015/2016.
What I would like to have:
text top
text bottom
instead I have, 'text top [square symbol] text bottom' over a segment/line.
I appreciate any advice on this issue.
Thank you,
Alexander
erik_jan
Forum|alt.badge.img+18
  • April 4, 2016
Have you tried using the TextStroker before the MapnikRasterizer?
Thank you for your prompt response. I am not sure if TextStroker can be helpful. I added a figure below to clarify my issue with the multi-line label - it looks that Mapnik doesn't process the new line character within the label.
erik_jan
  • April 4, 2016
By using the TextStroker you convert the text to a (line or polygon) geometry. I tried it and the newline is handled correctly by the TextStroker.
mark2atsafe
Forum|alt.badge.img+44
@alexandervstepa
If you use the StringConcatenator then click the Newline special character instead of typing \\n
That gives you a special character "LF" that works OK (at least it does for me in FME 2016.1)
Make sure Show Spaces/Tabs is turned on in the options of the StringConcatenator editor
The result is this:
gio
Forum|alt.badge.img+15
  • April 11, 2016
A newline is actually \\r\\n
It is a carriage return followed by a linefeed.
Remember the physical type writer?
You can even choose them in the texteditor in most transformers.
A newline can indeed by picked in a stringconcatenator. (wich i don't use mouch as mostly one can acces a texteditor)
mark2atsafe wrote:
@alexandervstepa
The result is this:
Mark, thank you for your answer. I did exactly that in the beginning. The problem happens with multi-line labels oriented along the lines. As soon as I select a labeling around a point - everything works fine. I am not able to do multi-level labels with orientation along a line.
Gio, thank you for your comment. I tried that as well - it looks the problem happens if the label is oriented along an edige/line - in such case Mapnik doesn't take a new line into account during label placement.
Hi Eric,
I will try to experiment with TextStroker.
Thank you.
mark2atsafe
  • April 15, 2016
mark2atsafe wrote:
@alexandervstepa
The result is this:
Ah, OK. I'll test that when I'm in the office next and file a bug report with the developers.
gio
  • May 9, 2018
@alexandervstepa
hmm... at an old post again..
use an attribute splitter, explode the list.
index= 0 and index 1 seperate inputs on MNR (same geometry of course)
Ofset 1 above the line and other below.
(but thats 2 years too late...lol)
