connect features with transformer (StatisticCalculator)
  • April 23, 2020
  • 23 views
terezia86
Hi there,
is there any way how to automatic connect all features from AttributeFilter with (each) StatisticCalculator?
or maybe any other Idea?
I do not want to do it manualy, because the AttributeFilter has about 400 features.
Thanks
Best answer by ebygomm
You would be better using a single statistics calculator with a group by. Instead of an attributefilter, have an attributecreator that creates those filter groups to use in the stats calculator
Forum|alt.badge.img+46
  • April 23, 2020
terezia86
  • April 23, 2020
Hi, the thing is that I need to get a sum of each feature separate, that´s why I wanted to do it separately. Or is this possible to achieve it also other way?
Maybe I just do not understand how do you mean this. can you more explain what is here to do?
Thanks
  • April 23, 2020
Thanks
The Group By option in the StatisticsCalculator when set will only sum together features that are in the same group. So you will get a different total per group
A simple workspace example
stats_group_by.fmw
terezia86
  • April 23, 2020
stats_group_by.fmw
Amazing! It has worked perfect!
Thanks a lot, you saved me a lot of time!
