Fanout and open folder
  • July 10, 2018
  • 6 replies
  • 37 views
mr_fme
Forum|alt.badge.img+9
I have a Workspace that I need in output create a folder and a subfolder, and in this subfolder the file needs to be saved. And after the file has been saved, I need the folder to open automatically, it can be done by the FME?
Thank´s
debbiatsafe
Forum|alt.badge.img+21
Hi @mr_fme
A FeatureWriter with either a SystemCaller or PythonCaller would be able to open the parent directory automatically after the file(s) has been written.
danilo_fme
Forum|alt.badge.img+53
  • July 10, 2018
Hi @DebbiAtSafe
This transformer SystemCaller is very interesting.
mr_fme
  • July 11, 2018
Hi @mr_fme
Very good. Thank´s
mr_fme
  • July 11, 2018
Hi @mr_fme
unfortunately neither the pythoncaller nor the systemcaller are working .. see the answer from pythoncaller:
PythonFactory failed to load python symbol `FeatureProcessor 'Factory proxy not initializedf_21 (PythonFactory): PythonFactory failed to process featureA fatal error has occurred. Check the logfile above for details
SystemCaller:
SystemCaller: Failed to Execute `start"" "C:\\Users\\FME\\Desktop\\Week\\18_07_10\\"'
Can you help me?
  • July 11, 2018
SystemCaller:
Can you help me?
  • Insert a space between the start command and the next double quotation mark.
  • Make sure that the specified folder definitely exists.
mr_fme
  • July 11, 2018
Help me a lot.
Thank you very much
