Multiple embedded transformer woes
  • April 27, 2017
  • 26 views
lifalin2016
Forum|alt.badge.img+40
I've made an embedded transformer to reproject an alphanumeric coordinate set, controlled by a published parameter set. It reads the "old" coordinates from two given attributes, and returns the reprojected coordinates values into the same attributes.
This works well enough, except when I have a dataset with two pairs of coordinates. It reprojects the first set fine, but completely ignores the latter, leaving them only partially processed.
I've tried to insert a FeatureHolder between them, but it looks like the two transformers in the same workflow interferes with each other ?
I've swapped the two transformers, and right enough, now the other set gets reprojected, while the former doesn't. So it's at least consistent.
Has anyone encountered something similar before ?
Cheers
Best answer by lifalin2016
Closing the question, as I honestly cannot remember whether it was solved another way, or just abandoned.
Forum|alt.badge.img+62
Are the attributes holding the coordinate values hardcoded in the custom transformer or are you handling those with parameters?
And what about the output attributes? If those are hardcoded instance 2 of the transformer will overwrite the results of instance 1.
lifalin2016
  • April 24, 2018
