How to detect missing values dynamically using PythonCaller?
  • June 27, 2019
  • 11 replies
  • 131 views
dataninja
I am trying to create a custom tool to help me do QA better and faster.
I have no problem detecting columns with null, empty ... etc but I really struggle to do so with <missing> values in PythonCaller.
Thanks for your help in advance.
Forum|alt.badge.img+46
  • June 27, 2019
Do you have a list of attribute names that you are looking for?
dataninja
  • June 27, 2019
Yes, I use the following function to do so.
Attribute_Names = feature.getAllAttributeNames()
jdh
Forum|alt.badge.img+40
  • June 27, 2019
You would need to have a reference schema, ie all the attributes that should be present.
If you bring that in to the python caller as a list (either reading an external file, or a list attribute)
You can then use
list(set(feature.getAllAttributeNames()).difference(schema_list))
dataninja
  • June 27, 2019
You can then use
Thanks, I will give that a try!
  • June 27, 2019
This will only give you the names of the attributes on the feature. You'll need a list of the attributes you are expecting to have to work out which ones are missing from the feature.
dataninja
  • June 27, 2019
You can then use
What is schema_list? I keep getting this error - Python Exception <NameError>: global name 'schema_list' is not defined.
jdh
  • June 27, 2019
schema_list is a placeholder variable.
In order to know what attributes are missing, you need to know what attributes should be present.
That can be hardcoded into the workspace, or preferably come from an external file.
  • June 27, 2019
You can also use the FMEFeature.getAttributeNullMissingAndType() method:
isnull, ismissing, attr_type = feature.getAttributeNullMissingAndType('my_attr')
This will let know know the disctinction between a missing attribute and a null value.
dataninja
  • June 27, 2019
Hi David, the function works great when I do one attribute at a time:
But it doesn't seem to work properly when I do it through a for loop:0684Q00000ArMG1QAN.png
Do you see anything wrong with my for loop?
jdh
  • June 27, 2019
the getAllAttributeNames() only returns attributes present on the feature. If 'Column 3' isn't present, it's never going to be checked in your loop.
That is why you need a list of all the attributes you want to validate.
dataninja
  • June 27, 2019
Oh I see, is there another solution to get all attribute names to use for the function then?
