Convolution and kernel filters for rasterdata
  • January 23, 2014
  • 7 replies
  • 30 views
Hello,
I am wondering if its possible to implement Imageprocessing tools in FME?
For instance: Lets say you have a LIDAR file and want to make presentable contours. You then take ur filltered LIDAR file, do some processing to it first, then you make contours, write the contourvector to a raster, and on the raster I would like to have to oportunity to do Image processing, with a convolution/kernel filter.
Can this be implemented i FME?
Best answer by kim
I am afraid that on the subject of convolution and other kernel techniques the answer is a no. At least, I tried this about 2 years ago and couldn't get it to work. Don't think it has changed since.
There's a possibility for small kernels: duplicating the raster onto different bands (say 8 times) and moving them all by 1 cell will allow you to make a fake 3x3 kernel, using a rasterexpressionevaluator and using different bands instead of different neighbours for the calculations. This gets cumbersome (and slow) fast.
I tried accessing the raster data from the python API to use it with a custom kernel processor, but I've not found a way to do this. Preferably you'd access the data as a 2D array, the rest is reasonably easy. If you do find a way, please let me know!
  • January 23, 2014
The ContourGenerator or the SurfaceModeller transformer can be used to generate contour from point cloud. And then, you can use the VectorOnRasterOverlayer to draw the contour onto a raster.
Try them.
Takashi
fmelizard
Forum|alt.badge.img+21
  • January 23, 2014
You will have to introduce the image processing filter yourself, since no transformer exists for the job.
See the following page for some examples.
Itay
Forum|alt.badge.img+5
  • January 24, 2014
  • January 27, 2014
Thanks for the reply. I will probably need a 7x7 kernel to smoothen the lines and its only one band, so I cant use this technik.
Guess I have to output the raster then to the kernel filtering.
helmoet
Forum|alt.badge.img+8
  • February 23, 2018
Hi, @paal, @kim, check this out! I tried to create a RasterConvoluter as an image processing tool on FME Hub. It only supports a single real*64 band type, however for starters sake... Anyway, FME has plenty of tools to translate any kind of raster to real*64 and back to colored images. Have fun with it.
deanatsafe
  • February 14, 2019
helmoet
  • February 21, 2019
Very happy (now find the time to play with it)!
