FME Workbench crashes when adding tester to canvas
  • October 29, 2018
  • 25 views
Hello,
My FME Workbenches crashes when I choose to add a tester transformer to the canvas.
My installation:
FME Desktop Oracle Edition (floating)
FME(R) 2018.0.1.0 (20180518 - Build 18310 - WIN64)
Every time I add a tester, the workbench just crashes, no warnings, no nothing. Is this a known problem or can someone help me out? Already tried reinstalling.
Thanks in advance!
erik_jan
Forum|alt.badge.img+26
  • October 29, 2018
It seems this is occurring frequently.
In that case submit a support request at: https://www.safe.com/support/
  • October 29, 2018
I just submitted a support request, thanks!
rahulsharma
Forum|alt.badge.img+10
  • October 31, 2018
Hi @d.vermeer
Is this happening when you add the transformer from Transformer Gallery or using Quick Add?
Can you try in Transformer Gallery --> Search for Tester
Try adding using the following methods
Double click
or Simply Drag and drop
Can you confirm if the crash occurs
when there are other transformers on the canvas
or only when adding it for the first time on the canvas
  • November 1, 2018
Hi @d.vermeer
Double click
Its occurs in every scenario. Tried everything you said. Wheter its the first transformer or not, FME still crashes.
