Waiting for System Caller to run multiple times before continuing with workbench
  • December 28, 2018
  • 37 views
oliver.morris
Forum|alt.badge.img+12
Thanks for the help in advance and happy holidays everyone.
I am running the SystemCaller to undertake a particular task, it takes a while and FME runs it multiple times.
The issues is I need FME to continue only after system caller has completely finished all the tasks.
Can someone please suggest a work around, I have tried a counter but not having much luck with it at the moment.
Thank you
Oliver
Best answer by takashi
@erik_jan is right, but if you need to wait for completion of all the tasks performed by entering multiple features to the SystemCaller, insert a FeatureHolder after the SystemCaller.
erik_jan
Forum|alt.badge.img+18
  • December 28, 2018
The SystemCaller transformer causes the workspace to wait until the call is finished.
That is the default behavior of the transformer.
See SystemCaller for the documentation.
  • December 28, 2018
oliver.morris
  • January 2, 2019
Thanks @takashi - hope you enjoyed your day our with Dale!
