can I make a single model for any CAD file to send it as Esri file geodatabase ? ( transform some lines in CAD to polygons in GIS )
  • June 15, 2017
  • 30 views
fmelizard
Forum|alt.badge.img+21
  • June 15, 2017
Hi @yasser_nl. Welcome to the FME Knowledge Center! Have you checked out the following demo CAD to GIS: Convert Parcel Lines and Text from DGN to Geodatabase ?
austinh
Forum|alt.badge.img+4
  • June 15, 2017
Use a Generic Reader to read you CAD file and pass the file name and location to the workbench with a Published Parameter. It is easiest if the layers in the expected CAD file are consistent. @yasser_nl
  • June 16, 2017
thank you very much .... this is useful but still suitable only for this project. I try to make one model works with any CAD file .
