Subtract list values from eachother based on index.
  • September 5, 2017
  • 5 replies
  • 204 views
jatoxa
Forum|alt.badge.img+12
For some reason I have a problem wrapping my head around this and I know it might be easier to solve with a script.
I have a list containing different numeric values and each value has an index. How would I go about to subtract one value with the next based on the index? For example;
If index = 5 then subtract value5 from value4
If index = 4 then subtract value4 from value3
If index = 3 then subtract value3 from value2........ etc.
There could be any number of values in a list so I need to somehow loop through all the values.
Thanks!
Best answer by danilo_fme
Hi @j2,
My Workspace has this struture bellow:
After i use the ListExploder and the attribute index of list is coming with the new attribute _element_index.
After i used the transformer AttributeManager and use the option Enable Adjacent Feature Attributes.
The result in Data Inspector:
Now you can do substract values.
Attached my template file created.
Thanks, - workspace-list.fmwt
Danilo
danilo_fme
Forum|alt.badge.img+52
  • September 5, 2017
Hi @j2,
Danilo
  • September 5, 2017
Could you possibly use the ListIndexer here?
Otherwise this could be a good candidate for a PythonCaller, it's generally much more efficient to loop over (large) lists in Python code than using the ListExploder etc.
jatoxa
  • September 5, 2017
Hi @j2,
Danilo
Hi danilo,
This works indeed, you more or less just clone and offset the index? Thank you for the solution!
/Jacob
jatoxa
  • September 5, 2017
Hi david,
I have already tested something in that direction.
Ultimately I think I will have to make the final solution with Python.
Thanks for the reply!
/Jacob
danilo_fme
  • September 5, 2017
Hi danilo,
/Jacob
Yes @j2, offset index with transformer AttributeManager
