DWG conversion - (poly)lines
  • December 18, 2017
  • 21 views
I have an AutoCAD drawing with some polylines and other types of objects and I converted the whole drawing to KML file.
Text have embedded hyperlink to external AutoCAD sheet sets.
When conversion is completed polylines also contain hyperlink which I do not want/need.
How can polylines be opted out from having embedded hyperlink.
Should I use Tester or GeometryFilter or maybe something else. I do not see polyline option in GeometryFilter , is Line option gonna work?
Thank you
  • December 18, 2017
hope-project-index.fmw
hope-project-index-map.dwg
This is my workflow and DWG file
Forum|alt.badge.img+49
Yes, the line option in the GeometryFilter will filter out polylines too
jneujens
  • December 21, 2017
If you need the polylines but do not want the hyperlinks coming with them, you can also use a AttributeRemover transformer (and then select 'Lists to remove' to delete the 'autocad_extended_data_list').
