KML to FME attribut
  • July 29, 2019
  • 11 views
Hello,
I want to do the same operation like this tutorial : https://knowledge.safe.com/articles/19918/how-to-expose-feature-attributes-from-kml-tag.html or this topic : https://knowledge.safe.com/questions/29326/how-can-i-extract-the-html-table-from-kml-descript.html
It consits in expose feature attributes from KML tag.
I've done the step with HTMLtoWHTMLconverter and I obtaint this :
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
    "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
  <title></title>
</head>
<body>
  Survey Parameters<br />
  <br />
  <hr />
  <table border="0" padding="10">
    <tr>
      <td></td>
      <td>Planned</td>
      <td>Current</td>
      <td>Desired</td>
    </tr>
    <tr>
      <td>Scan Frequency [Hz]</td>
      <td>66</td>
      <td>66</td>
      <td>66</td>
    </tr>
    <tr>
    ... I VOLUNTARY NOT DISPLAY ALL THE LINES
       <td>Speed [m/s]</td>
      <td>67</td>
      <td>62</td>
      <td></td>
    </tr>
  </table><br />
</body>
</html>
Then in XMLXQueryExtractor I adapt the request and I write this :
    declare default element namespace "http://www.w3.org/1999/xhtml";
    for $x in /body/div/table
    for $y in $x/tr
    return fme:set-attribute($y/th/text(), $y/td/text())
But in query results I don't have any new attribut, it doen't work...
I think that the solution is a little modification of the query but I don't know how to do , do you have any idea ?
Arnaud
debbiatsafe
Forum|alt.badge.img+20
Hi @arnaudfouch
The XQuery snippet you have posted is for a KML table with a different structure. Based on the snippet you posted, you will need to change from /body/div/table to /html/body/table/tr
In addition, your KML table is structured differently with 4 columns rather than 2 columns as is normally found in KML description tags. As a starting point, you can try the following XQuery:
for $c in 2 to 4
for $x in /html/body/table/tr
let $ind := /html/body/table/tr[1]
let $attrName := string-join(($x/td[1]/text(),(string($ind/td[$c]/text()))),".")
return fme:set-attribute($attrName$x/td[$c]/text())
The above XQuery should create list-like attribute names for your elements depending on the 'type' (eg. Scan Frequency [Hz].Current, Scan Frequency [Hz].Planned, etc.). Depending on your actual KML description tag output, you may need to modify this XQuery.
