User select shape / dynamic read featuretypes / Write fgdb
  • May 29, 2014
  • 11 views
My tasks to do with FME looks like this:
- Start the workspace and choose a shapefile.(The schema is not known before)
- Write the feature type with all attributes to a Filegeodatabase.
I can create a workspace with shapefile reader and dynamic fgd writer and a published parameter to get the input from the user.
But my problem is the reader which needs some predefined features.
If i select a shape file I get the following "unexpected Input" error: "some features were read that did not match a reader feature type...."
Is there a way to define the feature at runtime out of the input? Something like a dynamic schema reader?
Cheers
Best answer by takashi
Hi, try Merge Feature Type option on the reader feature type.
Takashi
  • May 29, 2014
Takashi
