fme pdf reader fatal error
  • March 7, 2019
  • 54 views
oliver.morris
Forum|alt.badge.img+14
I am trying to read in some pdfs, unfortunately when the pdf reader fails to open the pdf (if say it is corrupt) the workbench stops:
2019-03-07 15:40:24| 391.6| 0.0|FATAL |PDF Reader: Failed to open document '\\xxxx.pdf' because the file is not in PDF format, or because it is corrupted
I have set the workbench to ignore failed readers and continue transaction is setup under the Rejected feature handling.
Is there any way I can keep it running?
Thank you
Oliver
Best answer by david_r
You can wrap your workspace in a second workspace that uses the WorkspaceRunner transformer, passing the PDF filename as a published parameter.
  • March 7, 2019
oliver.morris
  • March 7, 2019
Will give that a spin. Thank you
