Identity_Insert in SQL Server Non-Spatial Error
I have one SQL Server Non-Spatial writter with ~80 tables (feature types), and need to insert into identity column. I enable this option in each writer's Feature Type, but it is still throws me error that FME cann't perform SET operation on my table(s).
What is all about?
Thanks
Be the first to reply!
